Easy question:
How do I set the center point of dynamic rotation on Solidworks?
Easy question:
Hello
The center of rotation is where the mouse pointer is on the part.
This is not necessarily noticeable when the room is small, but when you work by zooming, you can see the difference!
Kind regards.
I don't have a better one in store than Matthieu's answer
It's true that to go and find a detail, zoom in or out, take the whole thing back is obvious
Yes indeed, that's what I also had:
| View rotation (parts and assemblies only) | To rotate the model view: Hold down the caster and turn it to rotate. To rotate around a vertex, edge, or face: Click on a vertex, edge, or face using the wheel, then drag and hold. |
But I had in mind other options that can only be found on V5.
Thank you anyway.
Cédric.
