In order to optimize the prefs, I use speedpaks on the different assemblies and parts of a large assembly (so far so good).
My problem is that when I do the drawing of this big assembly (registration with item number), the quality of the views is locked on draft and therefore the prints are "ugly"...
Is there a way to get high quality views despite using speedpak? Or do you necessarily have to create configs without a speedpak for the drawing (and so the speedpak is useless ...)?
Very good speedpack practice for the management of large ASMs.
Speedpack is actually a slightly different form of configuration than the classic configuration. For example, if you dimension SpeedPak configurations in drawings, you can only dimension the edges included in SpeedPak (shown in black).
Therefore, for MEP, there are precautions to be taken. Watch here
