Hello
I have downloaded the attached hinge model, in .sldprt format. But unfortunately, the file is not listed.
Could you tell me which method to use for the side.
Thank you for your answers.
David
Hello
David
Hello
If you want to dimension your part in the 3D, you go to the sketch tab, then intelligent dimensioning, then reference dimension or DimXpert measurement dimension.
Or try to see, insert==>FeatureWorks==> recognize the functions but I don't guarantee anything.
The objective is really to rate the model or to prevent it from changing by a handling error?
