Here is the little reflection of the weekend
How to make this piece
Hello
On the other hand I can't determine if the snail is flat or rather conical? (if we look from the side)
Hello
In general it remains a sweep, your profile can be "swept thin" if you want it to be hollow, so the trajectory is a spiral.
I look at it when I have two minutes!
Hi @ Tomalam
it is slightly conical
We are reaching some limits of solidworks
Complicated with spiral smoothing, Sw doesn't want to have "crossed" volumes so I can just make the part with some light between the extrusions
it might work if we have time... Now it's your turn to show us! ;)
@ Tomalam
Always show what you've done
This will give ideas to the other participants
I could see with this piece that in surface we had a little more freedom compared to volume
It is true that several sketches must be made
at least that's how I proceeded, maybe there are others?
A priori I will make a "simple" smoothing surface following a conical spiral trajectory (trajectory obtained with the spiral function of solidworks projected on a cone).
Ah or maybe to do a cone type revolution and then dig the groove in the shape of a spiral and fix it all with leaves.
Then finish with the shell function.
Hello: result With CATIAV5
I didn't use a cone (but a revolution from a spline) is the spiral is variable-pitch.
See screenshots (the center is still to be finished and the internal intersections are cleaned).
I'll put you a link where you can find a lot of information about formulas on curves Click HERE
@ Tomalam it's not bad but I think you're blocked by the lack of profile
and + is you in volume
I could see that we are stuck + early (via the ratio radius of curvature / profile section) than on surface area why I don't know if someone can answer.....
However, we are on a basic log volume.......... (SolidWorks)
@ Thomas in sweeping I tried and you get stuck quickly
@ lucas it's a solution beware of the folds solidworks doesn't like contacts
@ fthomas your method is the one I used surface-smoothing
@ Tomalan you have to explain your last message to me don't understand well
@ Franck
under Catia it's actually easier than on SolidWorks
not the same product either
Thank you for the link to curve formulas
@Gt22 Here's what I thought I'd do but it doesn't look great. After I don't practice surface surgery so it's going to stop there for me^^
