Hello
I'd like to know if there is a practical function to make strings on Inventor 2012.
Thanks in advance!
Hello
Thanks in advance!
See this link
http://knowledge.autodesk.com/support/inventor-lt/learn-explore/caas/CloudHelp/cloudhelp/2014/FRA/InventorLT/files/GUID-438F8DED-72FA-460A-AB11-FBBD84194672-htm.html
Channel Dimension
Feature Group tab. On the ribbon, you can also click the Annotate
String Set Dimension
feature group tab. ![]()
Thank you for your answer!
Your answer thank you for your answer is far from being the answer that solved your problem
Writing down the answer that gives you the solution to your problem is beneficial to all the other readers and also to the provider of the answer who gets some points
And in no case if you name yourself the best answer will you collect points
You made me lose the 40 points allocated for this purpose
These are the habits and customs of the site
