Hello
Widely used in the automotive industry, how do you generate this type of grid with coordinate bubbles?
Thanks in advance
Hello
Thanks in advance
Hello, a priori the Viewgrid tool of mycadtool allows you to do this
Hello @j.morin
In the document properties, you can view and adjust the 2D grid, but without displaying the coordinates.
If it exists for CATIA, I'm interested
Hello it's not quite as similar but:
Apparently, CATIA, used by the big car manufacturers, doesn't know how to do ..!!!!
Hello, does mycadtool's viewgrid exist for catia V5?
normally the macro should be provided to you by the vehicle manufacturer
I had recovered a lot of them at the time, to adapt I don't know if it works with the current version of catia, I've only been working with SW for 5 years
renames the file Grid.CATScript (lynkoa does not support all extensions)
Quadrillage.txt (41.1 KB)
But man, that's exactly what I was looking for.
A THOUSAND THANKS!!
Ask your employer, if you are a subcontractor, there are about ten macros they already have, such as:
- copy paste the info of the points from the pdf into a txt file where a macro will retrieve and create the 'balls' contact points
Other macros to update properties from Excel
What is the name of your client if you are a subcontractor?
I'm all alone with a small equipment manufacturer. We work for Stellantis, RNMA.
I might as well tell you that no one can help me in my company
Stellantis is among others PSA, you should see if they can give you their macros, it's not the easiest
If you go to the site that's where you can get them in general
I've already tried but failed to install. Probably different version or hotfix.
