How to Retrieve Metadata from a Solidworks File
Hello
Can you tell me how to retrieve metadata from multiple Solidworks files in the form of an Excel table.
Let me explain:
- when you right-click/Properties on a part in the explorer, and there are properties related to the document, you have a customize tab with the properties entered in Solidworks.
so I would like to recover the data to create a plan EDM
Hello
These are the properties that are also in the room. I don't really understand: I would like to recover the data to create a "EDM" plans??? You need to create a text file to and link to these properties.
Here's a little file to show you how to do it...
proprietes.docx
Hello, it seems to me that it is not possible to retrieve them from Excel, you will have to go through a SolidXorks macro in VBA for example.
If it's to do it from an assembly, you could create a name with all these links so you have everything and then paste the name into an excel file.
Otherwise the question has already been asked...
http://www.lynkoa.com/forum/solidworks/comment-recuperer-metadonnees-fichiers-solidworks-sous-excel
As you are a mycadservice customer, you can export all the metadata of an assembly and its parts via smartbom. This software allows you to retrieve a bill of materials in excel format, among other things, by retrieving the different desired properties of each part.
This is what is said "smartbom" in the links of the question already asked.
