Sometimes I need to connect the midpoints of 2 entities, except that if I can select the 1st, selecting a second one is impossible for me.
I select the first point with a right click on the line, then " select midpoint ", but impossible to grab another one since a right click on another entity deselects the first selection...
So is it even possible to have 2 or more midpoints in the same selection?
If you draw your 2 segments with a midpoint line: SW puts you directly a real point in the middle that you can then select. So no addition of stitches or construction lines in a second step.
Sometimes, you just have to change your drawing method a little to make your life easier...
