Well! other mistakes
See the attached file!
Kind regards
erreur_de_contraintes_et_absence_de_contraintes.pdf
Kind regards
Good evening
Indeed I was noticing the problem on the feet. The second hole which is not on the center distance is well done on purpose to take small steps. I will modify the length of my stem.
I hadn't opened the sub-assemblies tab ...
I hadn't seen that the constraints of the spacers and feet had jumped, I'm modifying.
I'm really sorry, it's rookie mistakes... I really apologize, I really don't want to waste your time, I really try to understand each step.
Kind regards
Another small error (explanation attached)
Good evening
I changed the diameter of the tube, I discovered the interference function :D. Now the network is being :D !!!
For your information, why take the size of the Max stitches between 100 and 250?
Thank you very much for your valuable help.
Kind regards
