Configure a text sketch by room family
I'm starting to discover the configuration by part family and I was wondering if it was possible to change its text (done with the Text sketch tool) in the part family table .
Example:
I have a piece that says "HT / 1000". I then create a configuration because you need a second part that is slightly different in terms of dimensions and especially with the text "HT / 500" in exactly the same place as "HT / 1000". Is it possible to change it via the room family table?
While waiting for an interesting answer,
Upgrade to see if it's a little bit like that? If that's it, I'll explain to you how we do it. Part made under 2016
tu_o_-_3_avec_degaufrage_et_configuration_.sldprt
Yes, that's it. So how come?
You need to link your text to the "configuration name" property
After that, for the position, it depends on your sketch.
edits: larger image link;
Dsl for delay; here's how to do it in the ZIP file with the part
configurer_une_esquisse_texte_par_famille_de_pieces.zip
Thank you for your help and answers!
It's true that it's easier with the configuration name binding, I proceed differently because my marking is not always identical to the name of my configuration.
Hello, I am interested in this subject, however the download link and the explanations are no longer accessible.
Hello;
To bind the Text (sketch) to a property:
Use the " link to property " function, then choose
In the drop-down list the desired property:
Is the record broken?
:laughing::laughing: 8 years is probably not the record, but we are getting closer, however, if we count the double question, should we combine the two temporalities plus a penalty for digging up due to discussion???
https://forum.mycad.visiativ.com/t/configurer-une-esquisse-texte-par-famille-de-pieces/102115/8
https://forum.mycad.visiativ.com/t/parametrage-du-texte-de-cotation-via-la-famille-de-piece/114122
