Assembly constraints
Hello
In vba I make a program that opens in an assembly parts (of a bottle) and assembles them (complete bottle).
My problem comes to constrain the pieces in them.
As it is the user who chooses these parts, the mix between the open pieces will change.e.g: flat bottom, rounded bottom, rounded square edge, straight square edge etc...
What I started by doing is to constrain the plans of each room.
Macro registration code
Set Part = swApp.ActiveDoc
boolstatus = Part.Extension.SelectByID2("Wreath face@Bague Plane 26-1@Assemblage Round Edge", "PLANE", 0, 0, 0, True, 1, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Plan of face@EP-BR-ST-1@Assemblage Round Edge", "PLANE", 0, 0, 0, True, 1, Nothing, 0)
Dim myMate As Object
Set myMate = Part.AddMate3(0, 0, False, 0, 0, 0, 0.001, 0.001, 0, 0.5235987755983, 0.523598775983, False, longstatus)
Part.ClearSelection2 True
Part.EditRebuild3
boolstatus = Part.Extension.SelectByID2("Right Plan", "PLANE", 0, 0, 0, True, 1, Nothing, 0)
boolstatus = Part.DeSelectByID("Right Plan", "PLANE", 0, 0, 0)
boolstatus = Part.Extension.SelectByID2("Wreath droite@Bague Plane 26-1@Assemblage Round Edge", "PLANE", 0, 0, 0, True, 1, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Plan of droite@EP-BR-ST-1@Assemblage Round Edge", "PLANE", 0, 0, 0, True, 1, Nothing, 0)
Part.EditRebuild3
boolstatus = Part.Extension.SelectByID2("Plan_inf@Bague crown 26-1@Assemblage Round edge", "PLANE", 0, 0, 0, True, 1, Nothing, 0)
boolstatus = Part.Extension.SelectByID2("Plan_sup@EP-BR-ST-1@Assemblage Round Edge", "PLANE", 0, 0, 0, True, 1, Nothing, 0)
Set myMate = Part.AddMate3(0, 1, False, 0.071, 0, 0, 0.001, 0.001, 0, 0.5235987755983, 0.5235987755983, False, longstatus)
Part.EditRebuild3
We can see that there is a space between the two pieces of " 0.071"m and I don't know how to define it. (it will change for each set of parts so too restrictive especially since the part library will grow as you go along)
In my macro I intentionally put Y-shaped spaces to separate the parts when I import them (cf: image) so I know the space between the origin of the assembly and the center of gravity of my part. (is it the center of gravity that is taken into account when importing parts?)
Is it possible to recover the height of the room? (VBA variables)
Or any other ideas are welcome too!
Thank you
JB
Hello
To know a value of a dimension, it would have to have the same name in all the parts, for example:
D1@Extrusion1
In this case, it's not very complicated, see this link:
http://help.solidworks.com/2012/English/api/sldworksapi/Get_Display_Dimension_Properties_Example_VB.htm
Or else to go through all the dimensions of a part:
http://help.solidworks.com/2012/English/api/sldworksapi/Iterate_Through_Dimensions_in_Model_Example_VB.htm
Look in the API Help
GetBox Method (IComponent2)
or
GetPartBox Method (IPartDoc)
they return an array of coordinates corresponding to the wrapping cube
for the height following z => values(5) - values(2)
Hello
On the other hand, unless I'm mistaken, it's the origins that are superimposed by default when importing. Not the center of gravity.
Hi @ Jean-bapt
I ask myself the question?
you ask in a blend to be able to have the choice of configues #
if you create your assembly with x parameter
  • you have 4 sections
  1. Funds
  2. the bodies
  3. The passes
  4. Bottlenecks
  • In section 1 you have # types
 a_ flat bottom
 b_ rounded bottom
 c_ rounded square edge
 d_ straight square edge etc.
  •  In section 2 you have # types
  • a_b_c_d
  •  In section 3 you have # types
  • a_b_c_d
  •  In section 4 you have # types
  • a_b_c_d
Why not play on the assembly with fragmented parts
A common axis for this example case (constraint ref)
you put it all together
you make a splash by posing in each section (dotted rectangle)
the types corresponding to these sections
you hide the unwanted types
you gather your assembly to visualize
if it's OK for you registration
You still have to delete the unwanted pieces (which are hidden) on this recording
enregistrement_ plan_nomenclature_ etc
(I hope I was clear enough in my explanation)
Hello Gt22,
Thank you for your answer!
(I was working on some other things for the last two weeks)
I didn't quite understand what you mean by:
"You make a splash by posing in each section (dotted rectangle)
you hide the undesirable guys"
What I did in my macro is insert the pieces except that I want to insert them linked.
When you put the word "you" I would like the vba API to do it.
If you want I can show you what I did, there's nothing secret.
Like what:
Is it possible to insert pieces in an order and constrain them to the previously inserted piece?
Is it possible to link the dimensions of the parts together via API?
Thank you for your answers,
JB
which version of SW are you on?
I'm on SolidWorks 2012 in 64 Bits
Hello
Here are the specifications of my program, I want the user to :
-          Choose predefined items from a library
-          Choose the heights of each element
-          Choose the width or diameter of the bottle
-          Choose the capacity of the bottle
-          Choose the type of glass (material)
There are things that I can see later, the most important thing is the modification of the height of the pieces and the width and length.
Attached is an assembly of a bottle that could exist and whose parameters I would like to vary.
assemblage_bouteille_carre_droit.sldasm
