Otherwise it is possible to cheat with Solidworks by going through an assembly, save it as a part and then use FeatureWorks to rebuild the component... procedure described here:
But it's a lot of work for those who stay after the intern leaves
Careful! Removing the watermark does not mean removing the basic info of the room. The only way is to transfer non-native formats. Natively it's impossible or you have to expect to receive the traditional formal notice...
If it is possible @lionel_amieux_3 but only on justification and individual piece or 2-3 room max but justifying it which is complicated.
For a part that was used a lot (library), I had managed to get the version unlocked by Dassault (via Visiativ). But it's not easy. For a complete project, they will never agree to unlock anything!
At worst, leave the drawing on the student version and " if " the design is good and accomplished, redraw the draft project on the official version.
Hello This year at the Mycad in Lyon, it seems to me that they said that it was possible to have a license for a trainee for 3 or 6 months under certain conditions. Maybe to check/dig on the side of visiativ.
Bah! You have to weigh the pros and cons, he's only an intern, and even if he (or she) does his or her best, the chances that he or she will have to return to work afterwards are still important... (sorry, bad " Intern " experience in the past... )
Hello You can always try to install an official SW version. At the time you had 1 month of use without a license before blocking (probably painful pop-ups at startup each time): which allowed you to use SW while Dassault/your reseller gave you your license number. I am unable to know if this one-month period is still relevant.
In my time we started on autocad 2D, it's a good school to start with , like freeCAD Carry out the layout, import 2D views of the trace part, and when a license from the design office is available, model Well I'm old now
