Hi all
I want to make a diameter dimension on a cropped view in solidworks 2016. I only want to have half a rating line so as not to take up unnecessary space on my plan. I can't do it, can you help me please?
Hi all
Hello
Can you share your piece? so that I can try?
Here's a simpler piece with the drawing that illustrates my problem
Item1.SLDDRW (64.0 KB)
Item1.SLDPRT (62.5 KB)
Hello
Instead of defaulting to click Smart Dimension, expand the list and choose
then on the visible edge.
Thank you for the feedback but I don't have this option on my solidworks 2016, is there an option to check?
I just found it, you have to do a normal smart dimension and then you have to right-click, "hide the dimension line", and "hide the reminder line".
Thank you all for your help!
Hello
to provide a complement on the subject.
https://mycad.visiativ.com/en/contenu/comment-coter-une-grande-longueur-dans-une-vue-de-détail-0
May the force be with you.
Hello @testTole ,
The "symmetrical linear diameter dimension" option is only available since the 2022 version of SW. (if I'm not mistaken)
