Hello
We are looking to achieve a double dimensioning on a drawing, but with the first dimension in mm and the second in inch,
Is there a solution to perform this type of annotation in SolidWorks 2015?
Thank you for your help,
Kind regards
Hello
Kind regards
Hello
See here:
http://www.lynkoa.com/forum/2d/double-cotation-sur-mise-en-plan
Document Properties, then Dimensions and
Display with double rating
| Position of the dimension value | Superior Fiber |
| Low | |
| Right | |
| Left |
Hello
for the double dimension, simply click on the dimension and then in the creation tree select double dimensioning; And to put the dimension in inches in second or below, just go to tools==>option==>document property==>deploy dimensioning, then linear or ordinal depending on your dimension, and there is an area with the double dimension property and there you put underneath.
