Hello, I want to create a dimension in its minimum value on the plan unlike the 3D. I had found this trick with the forced dimensions but today we are forbidden this practice. On the other hand, we leave the practice to tinker with by creating the dimension, whiten the value and create a text. In short, a real aberration. Problem is that I have a Q-checker who checks my plan and refuses my first tip before putting it under a plm.
So I'm trying to find out if with the type of display, tolerance or other I can create a cleaner equivalent. My second solution is almost close but I would like to show only one terminal
