Hello
I have a statue repaired - broken foot -, to do this I downloaded a model in .stl that I would like to modify, namely to make a section/section following the sketched line - see attached image-, keep the " foot " part in order to create/re-model a connection between this foot and the -leg- part of the statue, the whole thing will be printed in plastic.
How do you make this cut/section with SW 2020? I attach a SW 2020 file
Item1G.SLDPRT (6.5 MB)
of the 3D model
thank you in advance
Unfortunately, an stl file is not editable with SW
Thank you, would there be another solution?
Check the site to see if there is any possibility to download it in another format.
Sometimes several formats are available
in . OBJ?
Hi, I've sanded the question and unfortunately there is no viable solution today for a graphic model armored with triangles such as this one, the solutions of transformation in surface will only clone more or less failed. There may be a way to dig into it to be able to split it through Meshlab and/or Blender...
thank you
I tried without result
@Alfoncpasmamob ![]()
On the other hand there is this option but I need the native STL
or on inventor
How to convert a mesh to a solid or polygon body in Autodesk Fusion
Hello,
You can use MeshMixer to split your STL files.
It is quite easy to use, especially for cutting by plane
Once your STL is imported into MeshMixer > edit/ plane cut
I'm looking at all this
thanks, I'll try with Cura
With Meshmixer it works well, otherwise the solution with Cura also exists but less flexible, because you have to place the model on the tray and sometimes you need supports...
thank you for your help
Result
PS: they could have saved 1 nail!!
An entrepreneur launches a hardware brand and asks his advertising friend to promote his new items. The first poster shows Jesus on the cross with the slogan
"With Dédé nails, it's for eternity!
Furious, the entrepreneur called his friend and shouted that it was unacceptable and too violent. He demands a new version.
A few days later, the friend came back with the new poster. We can simply see the hill of Calvary and the empty cross lying on the ground.
The new slogan: "With Dédé nails, it would never have happened!*
!!, well-known
