Cutting a Toolbox Component in Solidworks
Hello I have a cross-sectional view on solidworks but the toolbox component doesn't cut and I don't know how to do it.
Hello
I don't use Toolbox, but doesn't rendering the virtual component allow me to cut it? (right-click on the component in the tree, then "make virtual").
Good luck
Hello
The components in question must have the property ISFASTENER=1 to meet the standard by not cutting this component.
What type of component are you talking about?
Have you checked that the "Exclude fasteners" option is not checked
See image
A+
In your drawing, when you make a section view, the "Exclude Screws" option is checked by default. The components of the Toolbox are considered to be fasteners. So if you want to cut these components, just go to the properties of your section view, then go to the "Scope of Section" tab and uncheck the option. You can also have access to this option when creating your section view.
Kind regards
Thank you for your answers
