Sheet Metal Bending
Good evening everyone.
Here's my problem, I'd like to bend (deform?) a sheet metal with a central V-cut, so that my two vertices meet at a certain height represented by my construction line, except and this is the reason for my presence here, I can't do it.
I am attaching screenshots of the piece in question, if I have ever expressed myself badly or if there is a lack of information, do not hesitate to let me know.
Good evening
Regards
Capture tôle à plat
Capture tôle pliée
Hello @Théo_Bonnelie ,
You impose two constraints on your geometry:
  • the coincidence of the ends of the V-notch,
  • the altitude of their meeting point.
To comply with these constraints, we must act on two of the following adjustable parameters:
  • the length of the edges of the V-notch
  • the angle of the V
  • the angle of the bends of the triangular base of the sheet metal
  • the angle formed by these folds
Can you provide a draft of your part to have the main dimensions, and specify what is constrained and what can be modified?
Hello,
Rather than bending sheet metal, it would be much simpler and more judicious to transform a solid part into sheet metal.
Hello,
I agree with @froussel for the principle of a part converted into sheet metal, but the surface design has my preference...
Sketch1 in the right-hand plane allows you to define the expected altitude for the tip of the room.
Geometry generation:
  • creation in the " Face Plane" of the flat face of the base triangle
  • creation in the oblique " Plan1 " of the flat face of the flank,
  • creation in the " Plan3 " of the flat face of the side flange.
For the purpose of a future sheet metal part, the extreme tip of the base triangle is truncated (notching to avoid bend crossings), and the central edge of the oblique flank is slightly offset from the vertical plane of symmetry (1mm).
The " Sketch3D1 " allows you to define the edge of the V-notch in such a way as to respect the height dimension of the point.
Finally, symmetry of the oblique flank and flange, and stitching of the five bodies into one (which can then be laid flat).
The resulting surface body is then converted into a sheet metal part, thickness facing downwards, by marking the four plies.
Simply change the height dimension in Sketch1 to adjust the geometry of the sheet metal.
Solidworks 2022, Education Version: ToleEntailleV.SLDPRT (1.6 MB)
