Creating a Curved Cover for a Curved Door Handle
Hello,
I just replicated this door handle.
I need to " easily " reproduce the lid that will clip into the 5 notches located on the curved surface.
How do I do this easily and quickly starting from the curved cutout I made, please?
Is the easiest way to make a geodesic surface offset of 0.1mm for example and copy the sketch into a new room?
Poignee_Porte_Marco.SLDPRT (718.6 KB)
Lid.SLDPRT (100.9 KB)
Couverture.STEP (81.7 KB)
Hello;
Which version of Solidworks is used?
Please add a screenshot and/or a STEP or Parasolid equivalent for those who cannot open the attached file.
Parasolid is not allowed so I add the WWTP.
At the time for me for the Solidworks version, it's the 2025.
Poignee_Porte_Marco.STEP (1.2 MB)
Do you have a supplier reference?
It wouldn't surprise me if you can find the full 3D in a Find-il or tracepart download hub...
Otherwise, I'll work on the curved cut (Lid) in the assembly + 0.1mm reduced projection of the sketch of the 5 notches (One notch = one sketch to control the extrusion direction) and then a Draft function...
And I'll add a small notch or a removal of material on one edge so that I can remove it with a small screwdriver...
No, I'm sorry, I don't have any supplier reference anymore... I tried to search with the information I was given but without success and it's already been a while ...
I didn't use the draft. I copied and pasted the 3D sketch into a new part but by extruding it created a non-modifiable angle on the thickness of the part (see 3D file). When I try to change the angle of the plane to 45° for example, it changes the angle on the other side like with a mirror...
I'm going to try like you did there.
Can I create a part from assembly? and then modify it? And if I modify the handle, the lid follows, right?
I don't have Sldws in front of me anymore. But it seems to me that there is a way to:
  1. Create a large block of material
  2. integrate the original piece as a " derivative piece" in the large block 1)
  3. Subtract the derivative part from the large block
  4. Add the few necessary changes
This would allow you to have the " negative " of your handle to then work on what you want?
oh I like it as a technique, I'll see what I can do :wink:
Thank you very much for your answer.
If it can help you:
There, the guy is unbearable but it's with derivative parts
Oh yes not bad thank you for the videos :wink:
I admit that the guy is special :smiley:
Hello @3DLUV ,
A proposal using classic functions and which allows you to manage the play between the handle and the lid.
  • Create an " Offset Surface" of the bottom of the footprint, with an offset of 0.0 mm. This generates a new surface body: " Surface-Shift3 ".
    Hide the volume body of the " Leave2 " handle.
  • In a 3D sketch, create a sketch outline 0.5 mm away from the outer contour of the face by " Offset on Surface ". This value must be adapted to match the desired clearance between the handle and the future lid.
  • Use the " Restrict Surface " surface function to remove the outer edge.
  • Use the " Boss/Base " > " Thicken " function to give the plate its thickness (1 mm). Uncheck the " Merge result " box to create a second volume body, the lid.
  • This body can be saved as a part by right-clicking on the " Bulkhead " branch of the building tree, then " Save Bodies " option.
All that remains is to create the holding claws on the handle...
Good evening m_blt,
I just got back, I'll be able to try and look at everything you all advised me :wink:
It seems to me that your solution is not bad at all.
I'll let you know when I tried and if I can't, would it be possible to have the file modified? (if only to understand how you did it).
@ later.
No worries, both files are below.
:warning::warning: SW 2025 Education Version
Lid.SLDPRT (160.0 KB)
Poignee_Porte_Marco.SLDPRT (932.4 KB)
I'll first try on my own following your instructions and I'll look at your files if I can't do it, it will be more beneficial for me to learn how to do it :wink:
=> Good state of mind. :grinning:
Thank you Maclane :wink:
I just tried m_blt and I understood the logic well and the great thing is that if I want to change the handle and the lid " at the same time ", if I can say so, the isolated file of the lid updates itself!! I love !!
Thank you very much for this tutorial, it answered my request perfectly!! Are you on top !!
Poignee_Porte_Marco.SLDPRT (470.0 KB)
Poignee_Porte_Marco_Couvercle.SLDPRT (135.7 KB)
