Creating a variable dimension part
Hello,
I'm going around in circles on a subject, and I can't achieve what I want exactly.
I need to create a part, in this case a tube, that I could insert from the bookshelf into my assemblies and be able to select a diameter and a length.
The goal is to be able to insert several tubes of different diameter and length without redrawing them each time.
Do you know how I can do that?
The most relevant solution for the moment that I have found is to create a room with several configurations, but I can't change the length.
To put it simply, I need to do the same thing as the Toolbox tool with the screws. I choose a tube and then he offers me a diameter and a length.
Thanking you in advance,
Otherwise draw the part in the library, drag it to the desired location, make it virtual (right-click, make it virtual), then change the Ø and the length.
The virtual component is a virtual copy of the initial component (without any links)
