Is it possible to create an Excel or CSV file of a set of points with X, Y and Z coordinates from Autocad?
I hope I have been clear in my request
thank you in advance for your answers
Xavier
Xavier
Several possibilities, depending on the number of stitches and the repetitiveness of the task:
- a macro
- select the points, use the list command, copy and paste
There's the "_dataextraction" feature that allows you to do this and much more:
- "Insert" tab, "Linking and extraction" group, "Extract data" button,
- Page 1 : Radio button "Create a new data extraction", "Next >",
- You save the "DXE" template file (I don't really know what it's for),
- Page 2 : You have the choice between 2 options :
- Either you leave "Drawings/set of sheets" checked, but I advise you to have only your drawing open,
- Either you check the radio button "Select objects in the active drawing", then click on the button at the end of the line to select your points,
- "Next >",
- Page 3 : You check the boxes of the objects you are interested in (not necessarily just the points), "Following >",
- Page 4 : You uncheck the "Drawing", "General" and "3D Visualization" boxes in the right frame (filtering), then you check the X, Y and Z positions on the left, "Next >",
- Page 5 : (not tested) "Next >",
- Page 6 : You check the box "Output data to an external file (.xls .csv .mbd .txt)", then you click on the "..." button to give the file path, "Next >",
- Page 8 : "End"
The function allows you to go even further by studying it more closely !
There you go.
thank you for your answer,
I'll see later if my CSV file is usable for what I need.
I've known this manipe for a short time to do measurements on autocad,
For your information, on page 5 you have to uncheck all for the quantities because if you have two polylines of the same length it will only count one during the calculation
