Hello
I have to make a 500x500mm cube in 19 mm melamine panel (which will have a plastic cover to allow folding without breaking).
The machining (folding) will be carried out on a Nesting with a 90° tip that will leave 0.5mm of material.
the goal is to make the pattern of a cube (T-shaped) with slopes at 45° and then we would bend and glue the slopes at 45° to form the cube.
My problem is that I can't make my cube in 3D with these conditions with the sheet metal function (I'm in the wood and I never use it) to then have my unfolded. which I would send directly to the machine.
Could someone explain to me or have a solution to do this or send me a file with some side already realized that I would finish?
