Hello
In CuttingOptimization, I would like to know if it is possible to add a column showing the name of the part in which the profile is located. A column that appears during import, but not in the list of debits.
Thank you in advance
Stéphane
Hello
Can you make a screenshot of what you have in the flow list and what you have in the report?
In the report, we retrieve only the first two custom columns.
Kind regards
Hello, and thank you for this feedback.
When importing parts, the file name appears.
Subsequently, I do not find it in the list of debits, nor in the report.
We only recover the body properties.
So you need to add a property in the bodies, for example " File name", which retrieves the Sw-Filename variable.
Once this property is created, you need to add the column with the name of the body property.
Kind regards
Of course, I'll try.
Thank you!
Hello @fmarchand ,
I followed what you mentioned above to fix this problem, however I don't have anything that is displayed in the column created " Name " while in my body properties I do have the value.
How to do it?
Thank you in advance.
Leo
Hello
I also had this problem... I think it comes from SW who lacks an automatism...
In your room:
- Pin the right pane
- Select one of the items in the list of welded parts, this should reveal its properties:
- Click on apply, and presto:
Personally, I do it from time to time depending on the needs, but if it could be automated... Well, it's not Christmas yet!
Have a nice day.
Hello
From what I see in your screenshot, your property is not on a body property but a property of the room.
In this case, you must be there:
Kind regards
Hello
Thank you for your quick response.
I tried with " Designation " (screenshot in my 1st answer) and it still doesn't work. Is there a step to do between?
Hello
The capture you made is for the document properties, not the body properties.
Is this property present in field properties?
Kind regards
Hello
Thank you, that's right!
Kind regards.
