Jeśli dobrze rozumiem, czy chcesz rozbić wszystkie podzespoły?
Spróbuj tego:
Option Explicit
Dim swAssy As SldWorks.AssemblyDoc
Dim swComp As SldWorks.Component2
Dim swCompModel As SldWorks.ModelDoc2
Dim vComp As Variant
Dim blnDone As Boolean
Sub main()
Set swModel = swApp.ActiveDoc
Set swAssy = swModel
blnDone = False
While Not blnDone
blnDone = True
For Each vComp In swAssy.GetComponents(False)
Set swComp = vComp
Set swCompModel = swComp.GetModelDoc2
If Not swCompModel Is Nothing Then
If swCompModel.GetType = swDocASSEMBLY Then
swComp.Select4 False, Nothing, False
swAssy.DissolveSubAssembly
blnDone = False
Exit For
End If
End If
Next
Wend
