Hello
I am dealing with a problem that is currently insoluble, which I have recreated by pruning all the superfluous to submit it to you.
I have two pieces in one assembly, parts Y and Z. To locate bodies, we use a custom property "id".
- Y has two bodies: id Y1 and Y2, respectively designated "SLIDE" and "RING".
- Z has a body, id Z1 also designated "RING" (important).
I create an MEP of this assembly, with the aim of having a list of the bodies, with their respective ids and designations.
To do this, I break down the two mechanically welded parts into a nomenclature.
Problem: by decomposing Z and then Y, the nomenclature gets me two lines:
- Y1 quantity 2
- Y1 quantity 1
However, I would like to obtain, logically:
- Y1 quantity 1
- Y2 quantity 2
Which is indeed the case when I decompose Y and then Z, strangely!
It's as if Y2 by decomposing, both combines with Z1, but also changes the ID and designation! As if he could no longer find his young in decomposing.
I'm attaching a pack&go of this drawing, hoping you can find a solution to this intriguing problem.
Thank you in advance,
mise_en_plan.zip
