Hello,
I use a list nomenclature in tab, detailed numbering.
On the other hand, for presentation purposes, I would like a component repeated several times not to be grouped on a single line.
Kind regards.
Hello,
Kind regards.
Under Solidworks? I don't think that's possible, the purpose of nomenclature is to list the identical elements.
Hello
Indeed, it can appear in 2 different lines only if it is in 2 different subsets, and if we do not use the "flat nomenclature".
Uh, yes:)
Natively, I don't think it's possible, as said before, that's not the goal!
After that, nothing prevents you from saving the name on excel and then changing manually.
It will of course not be modified on Solidworks so I don't know if that's the goal...
Good luck
you can possibly do it if you use two configurations of the components with two different configuration names of course ... Even if the geometry is the same, then in the BOM options the grouping should be defined by configuration name and not by file name.
Thank you fthomas, that's exactly the conclusion I came to this lunchtime.
And it works perfectly.
Regards.
