Hello
How can I move a dimension to another view?
Hello
With the SHIFT key pressed, you move your dimension to another view
And with the CONTROL key to press, you make a copy of it on several views
In the case of a dimension imported from the model, this dimension must be projectable in the destination view, which is not always the case...
Hello
Hold Shift and Move --> removes the dimension from the initial view
Hold Ctrl and Move --> copies the dimension from the initial view
It doesn't always work, and sometimes you have to make the view uninterrupted for it to work.
Thanks for the answers but it doesn't work the Shift.
Indeed my question is if I can put a dimension like the image I attach (reference 201.3 or 210.15)
This is a ProE plan and the view is a detail view.
On ProE you move the rating on the view you choose.
Can I do this on SolidWorks?
What does that mean?
Remove the tie line from the rating?
I would like to take the dimension that I put on my view and move it into the detail view.
I would like the result as well as the image I attach.
Hello
For my example, the dimension of 3096 is an order so you just have to click on it in the detail view to put the dimension.
for the call number of 3081 click on order n°1 (on the detail view) then on order n°2 of the room.
may the force be with you.
Hello
For more information see the tutorial.
http://www.lynkoa.com/tutos/mise-en-plan/comment-coter-une-grande-longueur-dans-une-vue-de-d%C3%A9tail
