You can add feet on the periphery, if you feel it's right!
ok I understand better that way.
It has to accommodate 4 barrels so for stability I would maybe add a crossbar or two.
Hello @rhonatan
Give me your ASM file and I'll do the simulation for you.
Only specifies whether there can be two layers of kegs or not.
To complete @contact_168 's remark (which I salute by the way) I suggest you actually put two extra feet because you will never know what the operators and the carrists will do who are not always extremely delicate in the manipulations. for there is nothing to prevent them from putting three shafts and putting the third one precisely where there is no foot.
In addition, I often say it on this forum, for loads distant from the floor, you also have to define the maximum allowed overhang.
1°) because a lot of transpal tilts the load backwards before moving forward and in addition the fenwik can be led to overcome a bit of a significant slope and the pallet has to take all this.
Hi,Zozo and sorry for the delay, attached is the step.
Please let me know if I can reduce it to a section because the pallet is already very heavy.
palette_acier.step
Could you pass me your ASM and the parts (put everything with pack and go in a ZIP
It will be easier for simulation
Hello@ronathan
Here is a first report.
What we can remember is that I put the mass on a surface equal to the diameter of 4 barrels. But only a very small part of the bottom of the drum is 200 liter rolled steel sheet with a Ø 585 mm, height 880 mm and thickness 1 mm. The fulcrum is theoretically a point, but in order not to push the cork too far I put a 10 mm support. Either an inner diameter of 565 mm. This creates more constraints than if we put the mass distributed over the entire surface of the beams. This seems to me to be more accurate in relation to reality!
What I remember is the deformations of 2.5 mm (in static) but a safety factor of about 4 but with weak points that would deserve to be taken into consideration.
AMHA if I were you I wouldn't reduce the cross-section of the beams but I would put gussets placed in potentially critical places.
The only point in your design that I will revisit is the way the legs are attached.
The fork spacing of the Fenwicks is standard for Euro pallets but you have put central feet that are precisely in the path of the forks.
Indeed, I don't give much foot with the basic forklift operator if he rips the pallet horizontally to clear it as I see it all the time everywhere. We could also simulate the resistance of the feet with cases of misuse.
But you're the designer, I'm only doing an indicative simulation ;-)
palette_acier_from_zz-statique_1-2.pdf
Hello @ronathan
Are you sure of the mass of each of your kegs when they are full?
What is the material contained in the barrel (without indiscretion it is to check the total mass)
I added a horizontal force of 1000 N on the foot at the bottom right, it doesn't change much but it would be necessary to calculate the force necessary for the sliding of the whole to apply the right effort on the foot. But is it really necessary since you say nothing about welding?
To answer your question, this pallet is used to store barrels for 30 years whose contents I don't know. There will be 4 stacked pallets that will not move anymore so they will be handled only once. The total mass experienced by the first pallet is 7.6T + 3 times the mass of a pallet.
Good evening @ronathan
Thank you ;-) For these clarifications I better understand the position of the central legs which are therefore at the tangency point of two shafts each. On the other hand, you have two feet that will be in the void between the ground floor and the first and between the first and the second. You should simulate the whole thing so that you can be sure that everything is OK because it must change the game a bit!
Did you have time to take a look at the results of the simulation?
Yes, thank you for your static study. It confirms my choice of section, I will also follow your advice and add a gusset to the 4 corners along a U wing.
I don't know if you will read this message but for me there is a big problem or I don't have all the information.
I'll let you find it;-) @tous you can play too
Hello@stefbeno
No! No! no cooked ones, especially since each barrel is 200 liters (Hipsss! Bheueeeeu)
Did you find where and the bone in the design? The colors have nothing to do with what I consider to be a problem if each pallet is 450 KG!
PS: No boo-boos in the Alpes Maritimes for you or your loved ones I hope!
<HS climatic>: no boo-boo for me but it happened close. Seen from a distance it seems monstrous but geographically speaking, it's very local.</HS climatic>
We are talking about the problem of stacking: it is the drums that bear the weight of the stack. A "small" spacer between the pallets would be welcome, it seems to me.
Good evening @stefbeno
A spacer is not necessarily necessary according to the calculations (which only partially take into account the solidity of the drums because I don't know the model that will be used but I have drawn a standard model without a rim).
No! As @ronathan doesn't seem to be about to come back, I give the two points that for me are not correct.
1°) to put the first stage you can't use Fenwick because the forks can't go anywhere. Which would imply having a keg stacker with a stacking two kegs by two kegs on the top floor is not going to be glop. You would need something under the feet like in wooden pallets or steel wire bin pallets. Note that from the first floor the legs are no longer useful ;-)
2°) When I see this type of storage at CIRES, the drums for TFA waste are almost glued to each other because storage space is expensive. Currently, with the dimensions of the pallet @ronathan for it to resist and for the drums to rest on the pallet, they cannot be tangent to each other.
But hey, it's not the request of @ronathan that we give our opinion on the design. But between us it doesn't prevent us from asking ourselves questions ;-) ;-) ;-) If I'm off the mark, I'll always learn something!
Hi Zozo,
Sorry to answer late but I'm running out of time at the moment.
In fact, to be more specific with you, I don't have much information on this subject. I was only asked to estimate 250 galvanized steel pallets of 1400x1400 that can withstand a total load of 8T (sum of the 4 floors of drums) and this for storage for 30 years.
I can't afford today to spend time on a design for a deal that I might not have, so that's why I'm doing a big sizing (because you have to start with something at some point). Now I understand that the calculations pushed on my 3D model are not entirely correct. Nevertheless, for my costing, I must not be far from the truth?
Good evening@ronathan
Ok I understand;-) But if I'm not next to my shoes try to see if my remark about the forks that don't fit is relevant or not, because to solve this problem you'll have to add material and MO and this will influence the price quite a bit.
Good luck with your price offer ;-)
Hello ZoZo,
I'm coming back to the charge because the project is progressing a little. Here is a new version of palette. The stress has changed slightly because now the first pallet must receive a static load of 9T. This corresponds to 4 rows of 4 Ø650 kegs as well as the weight of the 3 top pallets.
Could you tell me if my new design holds up?
Thank you in advance ;)
palette_acier_1400_x_1400_v2.step
Good evening
I look and come back to you ;-)
Hello @Ronathan
Galley! misery!
Could you transform your ASM into a part before transforming it into a STEP otherwise I have to redo the whole ASM.
PS: small question , are you the one who defines the size of the pallet or are the dimensions imposed on you. If they are specialized pallets for keg storage, we could discuss the dimensions.
Second question why use UPNs instead of tubes because you could have more strength for a much lower overall weight and lower machining and welding costs and easier assembly for the AMHA welder. The vertical effort acceleration is much higher with tubes. Look at the attached image ;-)
In addition, some machining will cost you a fortune (compared to a kerf) without any real added value on the solidity, plus for the simulation I will have interference everywhere, look at this image
