Hello
I need to make a double dimension on my plans, the first dimensions in mm and the second in inches. On the other hand, I would like the one in inch (so in brackets) to be put below the one in mm. How to do it?
Thank you
Hello
Thank you
Simply enable the dual dimension option in the document options:
http://help.solidworks.com/2012/French/SolidWorks/sldworks/HIDD_OPTIONS
| Display with double rating | Select this option to view the dual units. |
| View Units for Dual Rating | Select to display the units for the second set of dimensions. |
| Position of the dimension value | Top |
| Under | |
| Right | |
| Left |
In the drawing click on 'Tools' / 'Options' and there choose the tab 'Document Property'
You can position the double dimension up/down or left or right as desired
See attached screenshot
Hello
Tools ==> options ==> properties of the document ==> dimensions ==> linear or ordinal and there you have double dimension and then you put it underneath.
Hello
I am attaching a pdf document to know where to pay it... but there is a problem, the mm are above the inches... but they have become crocheted... but I think it's already a small lead:) surely other people will be how to combine all of them;)
Good afternoon
