Hello
I'm a new user of Draftsight.
I want to delete blocks with the purge function, here is the message I receive.
What should I do ?
Thanks in advance
Marc
Hello
What should I do ?
Thanks in advance
Marc
Hello
I think that the block definition function (in the "create block" function), then a deletion of the different blocks and then a purge should help you.
Otherwise by using the function to break the blocks and purge, would that solve your problem?
Hello Azrod,
Thank you for your answer, but it doesn't work.
I always get the same message.
Apparently the reference should be deleted, but I can't do it.
The problem lies in the fact that there must be blocks inside other blocks, I have the impression.
This must involve the removal of the first, second, third level blocks, etc.
Here is a link that may help I think:
https://forums.autodesk.com/t5/autocad-francais/comment-supprimer-les-blocs-inutiles/td-p/2296725
Hello Marc,
You need to check the "Show entities without references" option!
In your screenshot, these are the non-purgeable items that are listed!
A+
Hello again and thank you for your answers,
But it still doesn't work :-(
