Hi all I am currently reconnecting drawings from a service provider. Beyond his incompetence that I accept, after having helped him in these choices. And his departure after an unequivocal observation on his level, a lie and probably a mythic CV. As I say, I re-point the drawings, and see its level. And I'm surprised by the different problems encountered.
Nomenclature not attached to the model present on the plan, but on a view placed outside the field, from another model.
Fake detail view: let me explain, the man makes a detail view, the circle lines it with a sketch, and produces a detail view outside the frame on another view. Make-up the whole thing so that it coincides. Lucky or not, he uses the same model.
The 126 MB drawings, after 27MB cleanup. The work produced is unreliable. The worst thing is that we help a subcontractor to do their work, we pay them and we work in their place
In short, the list could be exhaustive but I'm tired of repairing the mess created since the beginning of my project by this company.
But I came across a Bone, now I don't understand how he did? One of the views uses a named assembly in the tree, and when opened has a different name??? Any idea? or I wonder if I should take this me...
Hello It is possible that the file name changed between creation and availability without saving by doing a refresh. So it displays the right name when opening and then if you go back to the drawing it has certainly updated. After that, there is the bug depending on the version of SW. For the subject itself, in view of what is exposed, it is clearly incompetence. Unfortunately SW (and CAD tools in general) are so democratized and simplified that anyone can get something out of it without worrying about the logic and someone else taking it back.
I note your answer, I also think of an update that does not want to be done.
But clearly I am dealing with a sneaky person , born of a frustration due to his incompetence. Because the guy tried to make, and I must say that all this energy to do that will always amaze me. After two years of explaining to him how to do it well, the worst thing is that he comes from aeronautics .
If you have examples of bad moves, I'm all for it.
A beautiful one that I identified a long time ago. The function is carried out correctly with the help of its skeleton, it is asked to adjust the part. A normal person does a search for the original constraints to find the sketch and modify it. No, we use the stretch function, I only come across geniuses. " is look I know all the functions of SW " @Sylk tell me at Boeing they used the stretch function to go from Boeing 737 to 747?
Personally I would have rather removed material in the middle, moved one of the 2 bodies and then merged everything: it's much more stable than the ladder function
Joking aside, this is also the strength of SW: being able to achieve the same result with 20 different methods / functions.
Your projector clearly didn't do what most people would have done but he probably made the fastest modification (no need to bother analyzing an 8-page tree to find the pilot sketch and modify it, he just set his function and that's it).
NB: I'm not particularly proud of it but I also used this kind of shortcut rather than the ' logical ' modification because the ' logical ' modification was way too time-consuming (if the modification of the basic sketch results in a red construction tree for example and it forces to correct dozens of sketches / functions).
I also went through tolerance on the means. But in the context of large projects, or more or less large projects, we try to set up methods. In this case we are using skeletons, an exercise that requires a little practice, but nothing insurmountable. But if you ask for a cylinder and the guy starts with the thickness you ask yourself legitimate questions. I am not saying that a square can be made by a revolution and a removal of rectangular matter. But on large models, if you don't save on function, it can be felt on the plans. SolidWorks, Catia, Inventor etc, can all do the same thing in different ways, and I don't judge, I explain why it would be better this way and I try to argue simply with the most pedagogy. But when the guy tells you I know and does something that has nothing to do with it, well you know what he thinks Here the thing is that making a detail from an existing view is super fast. On the other hand, importing a view and cropping it so that it looks like a circle , and making a circle and a sketch and disguising it as a function, it's not fast , and the list of these misdeeds is long Bred is a thing of the past
