Hello
I'm on SW2016 SP03 and I need to have two identical and linked BOMs (in order to minimize the source of error in case of modification) on two sheets of the same document.
I found this:
The Nomenclature PropertyManager
Specify the properties of the BOMs.
To open the BOM PropertyManager , do one of the following :
- Click BOM
on the Table toolbar or, in an open document, click Insert > BOM >Tables.
- Click the translation
icon in the upper-right corner of an existing BOM.
BOM Options
| Create a new table | Creates a new drawing table. |
| Copy an existing table | Copies a saved BOM from an assembly or part. Select a BOM from the list. Select Linked to link the data in the drawing BOM to the assembly BOM. Once the link is broken, it cannot be restored. Changes to one of the BOMs are reflected in the other. Formatting is not linked. |
See http://help.solidworks.com/2016/french/SolidWorks/sldworks/HIDD_DVE_INSERT_BOM.htm
Problem: the "BOM options" tab does not exist at home (see attached screenshot).
Currently the only solution I have is to copy and paste the sheet. The nomenclature is duplicated but the 2 are not linked and the 2 must then be modified, which is annoying and a source of errors.
Thanks in advance:)
