Solidworks Equation
Hello
When I type the parameters of an overall rating then I validate with "ok" an error message that is displayed!
"There is a mistake in the active equation"
Thank you for helping me.
The problem comes from a windows update:
 https://www.solidworks.com/sw/support/TechKB3072630.htm
1. Uninstall SOLIDWORKS
2. Disable Windows Update 'KB3072630'
3. Reinstall SOLIDWORKS
4. Re-enable the update
Otherwise, you can also try to disable the update and repair solidworks
It should work too ;-)
Update deactivation link:
https://www.solidworks.com/sw/docs/KB3072630_Workaround.zip
Normally no need to uninstall.
You disable the update as explained here:
http://www.mycadblog.fr/problemes-solidworks-rencontres-apres-la-mise-a-jour-de-microsoft/
You repair Solidworks.
You reactivate the update
