Je suis sous SolidWorks 2022 et le code est le suivant :
Sub recupTranparenceImage()
Dim swSelMgr As SldWorks.SelectionMgr
Dim swSketchPicture As SldWorks.ISketchPicture
Dim boolstatus As Boolean
'Dim instance As ISketchPicture
Dim Style As Long
Dim Transparency As Double
Dim MatchingColor As Long
Dim MatchingTolerance As Double
Set swModel = swApp.ActiveDoc
'boolstatus = swModel.Extension.SelectByID2("Feuille1", "SHEET", 5.43900806628579E-02, 0.13276815279762, 0, False, 0, Nothing, 0)
swModel.EditTemplate
swModel.EditSketch
boolstatus = swModel.Extension.SelectByID2("Image d'esquisse2", "SKETCHBITMAP", 0.166852606603703, 0.134853758836237, 0, False, 0, Nothing, 0)
Set swSelMgr = swModel.SelectionManager
Set swFeat = swSelMgr.GetSelectedObject6(1, -1)
Set swSketchPicture = swFeat.GetSpecificFeature2
'Debug.Print swSketchPicture.SetTransparency(2, 0.97, 0, 0)
Debug.Print swSketchPicture.GetTransparency(Style, Transparency, MatchingColor, MatchingTolerance)
Debug.Print Transparency
swModel.EditSheet
Oui merci @Sylk , c’est exactement ce que je venais de tester, grâce a ta réflexion de valeur retourné par la fonction:
Dim Style As Long
swModel.EditSketch
swSketchPicture.GetTransparency Style, Transparency, MatchingColor, MatchingTolerance
swModel.EditSheet
