Hello
I can't exclude a component (.sldprt or .sldasm file) with the MYcadtool " Integration " tool.
I perform file conversions (.sldprt and .sldasm to STEP and .slddrw to PDF and DWG) and I would like to add a condition so that it does not process my " Nomenclature " files, but I can't find this condition in the tool.
Thank you in advance.
You have to go through Smartbom to extract your list of BOM files (the path of the file), (the excluded components will not be in the list), with the possibility of adding other criteria also according to property(s).
Then in Integration you import the extracted list and you launch the task(s) to be done on this list.
That's how it should work.
Hello
Thank you for your feedback.
It is not possible to do this directly on integration?
Not for me. Unless I missed a hidden rule, but I doubt it.
For smartbom export:
Creating the template in 1, adding the file path in 2
In option 3 take text export in 4 then check the export option via txt file in csv format.
Then in integration, drag the csv or right-click import a csv file in the area of files to be processed.
