Je souhaiterais appliquer une macro qui modifie les unités de toutes les pièces d'un assemblage (voir d'un dossier) sans avoir à les ouvrir une par une.
J'ai déjà le code pour la modification des unités mais il me manque la partie pour l'appliquer à tous les éléments d'un assemblage (pièces essentiellement).
Quelqu'un saurait-il m'aiguiller?
change_unites.swp
Regarde cette macro qui traverse un assemblage de part en part en part:
' Preconditions:
' 1. Open an assembly document containing nested subassemblies.
' 2. Open the Immediate window.
' Postconditions:
' 1. Traverses the assembly.
' 2. Examine the Immediate window.
Option Explicit
Sub TraverseFeatureFeatures(swFeat As SldWorks.Feature, nLevel As Long)
Dim swSubFeat As SldWorks.Feature
Dim swSubSubFeat As SldWorks.Feature
Dim swSubSubSubFeat As SldWorks.Feature
Dim sPadStr As String
Dim i As Long
For i = 0 To nLevel
sPadStr = sPadStr + " "
Next i
While Not swFeat Is Nothing
If swFeat.GetTypeName = "Reference" Then
Debug.Print "0:" + sPadStr + swFeat.Name + " [" + swFeat.GetTypeName + "]"
End If
Set swSubFeat = swFeat.GetFirstSubFeature
While Not swSubFeat Is Nothing
Debug.Print "1:" + sPadStr + " " + swSubFeat.Name + " [" + swSubFeat.GetTypeName + "]"
Set swSubSubFeat = swSubFeat.GetFirstSubFeature
While Not swSubSubFeat Is Nothing
Debug.Print "2:" + sPadStr + " " + swSubSubFeat.Name + " [" + swSubSubFeat.GetTypeName + "]"
Set swSubSubSubFeat = swSubSubFeat.GetFirstSubFeature
While Not swSubSubSubFeat Is Nothing
Debug.Print "3:" + sPadStr + " " + swSubSubSubFeat.Name + " [" + swSubSubSubFeat.GetTypeName + "]"
Set swSubSubSubFeat = swSubSubSubFeat.GetNextSubFeature()
Wend
Set swSubSubFeat = swSubSubFeat.GetNextSubFeature()
Wend
Set swSubFeat = swSubFeat.GetNextSubFeature()
Wend
Set swFeat = swFeat.GetNextFeature
Wend
Sub TraverseComponentFeatures(swComp As SldWorks.Component2, nLevel As Long)
Set swFeat = swComp.FirstFeature
TraverseFeatureFeatures swFeat, nLevel
Sub TraverseComponent(swComp As SldWorks.Component2, nLevel As Long)
Dim vChildComp As Variant
Dim swChildComp As SldWorks.Component2
Dim i As Long
For i = 0 To nLevel - 1
Next i
vChildComp = swComp.GetChildren
For i = 0 To UBound(vChildComp)
Set swChildComp = vChildComp(i)
Debug.Print sPadStr & "+" & swChildComp.Name2 & " <" & swChildComp.ReferencedConfiguration & ">"
TraverseComponentFeatures swChildComp, nLevel
TraverseComponent swChildComp, nLevel + 1
Next i
Sub TraverseModelFeatures(swModel As SldWorks.ModelDoc2, nLevel As Long)
Set swFeat = swModel.FirstFeature
Sub main()
Dim swConfMgr As SldWorks.ConfigurationManager
Dim swConf As SldWorks.Configuration
Dim swRootComp As SldWorks.Component2
Dim StartTime As Double
Dim FinishTime As Double
Dim TotalTime As Double
Set swApp = CreateObject("SldWorks.Application")
Set swModel = swApp.ActiveDoc
Set swConfMgr = swModel.ConfigurationManager
Set swConf = swConfMgr.ActiveConfiguration
Set swRootComp = swConf.GetRootComponent3(True)
StartTime = Timer ' Start time
Debug.Print "File = " & swModel.GetPathName
TraverseModelFeatures swModel, 1
If swModel.GetType = SwConst.swDocASSEMBLY Then
TraverseComponent swRootComp, 1
End If
FinishTime = Timer ' End time
TotalTime = FinishTime - StartTime ' Elapsed time
Debug.Print ("Time = " & TotalTime & " sec")
Elle t'affiche le nom de chaque pièce, assemblage, et même fonction de l'assemblage principale.
Il te suffit ensuite grâce au nom ou au chemin à ouvrir la pièce demandé appliqué ton code, l'enregistrer et la fermer.
Pour d'autre exemple fait une recherche avec macro solidworks et traverse components.
EDIT: Et la version API SW:
https://help.solidworks.com/2020/english/api/sldworksapi/Traverse_Assembly_at_Component_and_Feature_Level_Example_VB.htm?verRedirect=1
2 trois autre exemple en vrac:
https://stackoverflow.com/questions/60000471/saving-all-parts-in-an-assembly-as-step-with-custom-properties-how-to-solve-run
https://r1132100503382-eu1-3dswym.3dexperience.3ds.com/#community:yUw32GbYTEqKdgY7-jbZPg/iquestion:6lAv8HurTReoBjJqUe3xIg
Sinon vous pouvez le faire sans code avec l'outil integration de myCADtools :
![](https://www.lynkoa.com/sites/default/files/from_ckeditor/integration_lancer_macro.gif)
L'aide sur Integration : https://help.visiativ.com/mycadtools/2022/fr/Integration.html
Opération pour lancer une macro : https://help.visiativ.com/mycadtools/2022/fr/Integration186.html
Vous pouvez test myCADtools pendant 30 jours si vous n'avez pas d'abonnement myCADservices Premium : https://www.lynkoa.com/mycadtools
Bonne journée
Philippe
