Il est plus simple d'afficher directement le code plutôt que de joindre la macro:
Const INCLUDE_DRAWING_NAME As Boolean = True
Sub main()
try_:
On Error GoTo catch_
Dim swDraw As SldWorks.DrawingDoc
Set swDraw = swApp.ActiveDoc
Set swModel = swDraw
If swModel.GetPathName() = "" Then
Err.Raise vbError, "", "Please save drawing"
End If
Dim vSheetNames As Variant
Dim i As Integer
Dim swSelMgr As SldWorks.SelectionMgr
Set swSelMgr = swModel.SelectionManager
Dim selSheetNames() As String
For i = 1 To swSelMgr.GetSelectedObjectCount2(-1)
If swSelMgr.GetSelectedObjectType3(i, -1) = swSelectType_e.swSelSHEETS Then
If (Not selSheetNames) = -1 Then
ReDim selSheetNames(0)
Else
ReDim Preserve selSheetNames(UBound(selSheetNames) + 1)
End If
Dim swSheet As SldWorks.Sheet
Set swSheet = swSelMgr.GetSelectedObject6(i, -1)
selSheetNames(UBound(selSheetNames)) = swSheet.GetName()
End If
Next
vSheetNames = swDraw.GetSheetNames
Else
vSheetNames = selSheetNames
End If
For i = 0 To UBound(vSheetNames)
Dim sheetName As String
sheetName = vSheetNames(i)
Dim swExpPdfData As SldWorks.ExportPdfData
Set swExpPdfData = swApp.GetExportFileData(swExportDataFileType_e.swExportPdfData)
Dim errs As Long
Dim warns As Long
Dim expSheets(0) As String
expSheets(0) = sheetName
swExpPdfData.ExportAs3D = False
swExpPdfData.ViewPdfAfterSaving = False
swExpPdfData.SetSheets swExportDataSheetsToExport_e.swExportData_ExportSpecifiedSheets, expSheets
Dim drawName As String
drawName = swModel.GetPathName()
drawName = Mid(drawName, InStrRev(drawName, "\") + 1, Len(drawName) - InStrRev(drawName, "\") - Len(".slddrw"))
Dim outFile As String
outFile = swModel.GetPathName()
outFile = Left(outFile, InStrRev(outFile, "\"))
Debug.Print outFile
Debug.Print sheetName
outFile = outFile & IIf(INCLUDE_DRAWING_NAME, drawName & "_", "") & sheetName & ".pdf"
If False = swModel.Extension.SaveAs(outFile, swSaveAsVersion_e.swSaveAsCurrentVersion, swSaveAsOptions_e.swSaveAsOptions_Silent, swExpPdfData, errs, warns) Then
Err.Raise vbError, "", "Failed to export PDF to " & outFile
End If
Next
GoTo finally_
catch_:
swApp.SendMsgToUser2 Err.Description, swMessageBoxIcon_e.swMbStop, swMessageBoxBtn_e.swMbOk
finally_:
Pour comprendre le code il suffit d'ajouter des debug.file et de regarder la fenêtre d'exécution
La partie qui te concerne:
outFile = Left(outFile, InStrRev(outFile, "\")) ' récupère le chemin de la mise en plan
Visible avec debug.file "outFile" & outFile 'affiche c:\temp\
Ensuite:
Cette ligne définie le nom de ton fichier pdf drawName récupère le nom de ton fichier drawing et sheetName le nom de la feuille.
Ensuite If False = swModel.Extension.SaveAs(outFile, swSaveAsVersion_e.swSaveAsCurrentVersion, swSaveAsOptions_e.swSaveAsOptions_Silent, swExpPdfData, errs, warns) Then
End If
Exporte ton fichier en pdf ou affiche un message d'erreur.
Maintenant il faut ajouter une condition si ta feuille sheetName commence par découpe tu récupère ce qui reste du nom de ta feuille t tu exporte en dwg au lieu de pdf.
Indice regarde la fonction vba If et aussi la fonctionSplit
