Bonjour à tous.
J'ai récupéré un programme en VBA pour exporter ma nomenclature dans un feuille en .xls
Tout ce passe bien sauf pour une option que je n'arrive pas à modifier.
Je souhaiterais que le programme choisis la configuration en cours.
Actuellement il cherche la configuration nommé "Défaut"
Configuration = "Défaut"
Si quelqu'un connais la réponse :)
Insert BOM Table and Extract Data Example (VBA)
This example shows how to insert a BOM table and the extract the data from it.
' Preconditions:
' 1. Verify that the specified drawing document to open
' exists.
' 2. Open the Immediate window.
' Postconditions:
' 1. Opens the specified drawing document.
' 2. Selects a drawing view.
' 3. Inserts a BOM table at the point where the drawing
' was selected.
' 4. Examine the drawing and Immediate window.
' NOTE: Because the drawing is used elsewhere, do not
' save changes.
Option Explicit
Sub main()
Dim xlApp As Excel.Application
Set xlApp = New Excel.Application
Dim wbk As Excel.Workbook
Dim sht As Excel.Worksheet
With xlApp
.Visible = True
Set wbk = .Workbooks.Add
Set sht = wbk.ActiveSheet
End With
Dim swModelDocExt As SldWorks.ModelDocExtension
Dim swBOMAnnotation As SldWorks.BomTableAnnotation
Dim swBOMFeature As SldWorks.BomFeature
Dim boolstatus As Boolean
Dim BomType As Long
Dim Configuration As String
Dim TemplateName As String
Set swModel = swApp.ActiveDoc
TemplateName = "M:\DATABASE\MODELES\05-Model de nomenclature\GP_ASM_Nomenclature BOS.sldbomtbt"
BomType = swBomType_Indented
Set swBOMAnnotation = swModelDocExt.InsertBomTable3(TemplateName, 0, 0, BomType, Configuration, False, swNumberingType_Detailed, True)
Set swBOMFeature = swBOMAnnotation.BomFeature
swModel.ForceRebuild3 True
Dim NumCol As Long
Dim NumRow As Long
Dim I As Long
Dim J As Long
NumCol = swBOMAnnotation.ColumnCount
NumRow = swBOMAnnotation.RowCount
For I = 0 To NumRow
For J = 0 To NumCol
sht.Cells(I + 1, J + 1).Value = swBOMAnnotation.Text(I, J)
Next J
Next I
boolstatus = swModelDocExt.SelectByID2(swBOMFeature.GetFeature.Description, "BOMFEATURE", 0, 0, 0, True, 0, Nothing, 0)
swModel.EditDelete
Dim config As SldWorks.Configuration
Dim cusPropMgr As SldWorks.CustomPropertyManager
Dim lRetVal As Long
Dim ValOut As String
Dim ResolvedValOut As String
Dim wasResolved As Boolean
Dim nNbrProps As Long
Dim vPropNames As Variant
Dim vPropTypes As Variant
Dim vPropValues As Variant
Dim resolved As Variant
Dim custPropType As Long
Dim K As Long
Dim NomProperty As String
Set config = swModel.GetActiveConfiguration
Set cusPropMgr = config.CustomPropertyManager
nNbrProps = cusPropMgr.Count
vPropNames = cusPropMgr.GetNames
For K = 0 To nNbrProps - 1
cusPropMgr.Get2 vPropNames(K), ValOut, ResolvedValOut
custPropType = cusPropMgr.GetType2(vPropNames(K))
If vPropNames(K) = "DESSINATEUR" Then
NomProperty = ResolvedValOut
End If
Next K
Dim chemin As String
chemin = "C:\temp\BOS.xlsx"
With xlApp
wbk.SaveAs chemin
wbk.Close
.Quit
End With
insert-bom-asm_-_03.swp
