Solidworks 2015 sp3
I can choose "this configuration" with the "config" icon in the corner value change box, but when I change the value, this value is applied to all configurations.
Solidworks 2015 sp3
You should not use the button located in the constraint menu, it does not work,
On the other hand, by double-clicking on the constraint, we make the corner dimension appear in the 3D and by clicking on it we can modify it like any other dimension and therefore choose the configuration if we want.
Hello
Have you tried the "Configure dimension" command when you right-click on the corner dimension?
Hello
Try to delete (delete not delete/delete) your constraint with the initial angle and create another (the same) constraint with the new desired angle.
Hello
FYI, this is a SOLIDWORKS bug, here is the reference in the knowledge base:
| 438977 | Modified dimensions (this configuration) are changing in every configuration, if edited with Featuremanager | Open |
