I want to clean up an assembly folder with the CleanProject function of MyCADServices. However, it does not run properly because it asks me to rebuild the assembly. So I opened the rebuilt assembly file, closed, but I still have the same problem. Do you have any ideas to solve this?
I see that you are on a "cloud" space, have you ever used CleanProject on this kind of space? Otherwise, try copying the files locally and running CleanProject on the copy.
In this case, check in the "deleted" files that there is not one that is used. I had the problem with this tool. Typical case: takeover of a commercial part. The commercial part is called in another part to do the machining, the file of the commercial part was ejected...
