Hello
I'm contacting you because I make drawings but I can't get my ratings because the function is not present in my solidworks while my colleague has it.
Do you have an idea?
Hello
It's up to you to ratchet on the lines of the dimensions and remove them
if I understood the question correctly
Hello GT22,
I think you didn't understand the question, I didn't want to remove the rating from my plan but to make a display change.
Thank you.
What does that mean?
Hello
The "off-hook" option is accessible for dimension lines, so 1 left click on the dimension line to be off-hook and then right-click / Display option / off-hook.
Kind regards
Hello d.roger,
Thank you for your answer, however the problem is that in the display options, the function is not present (see photo attached to the 1st message)
Thank you in advance.
Was the context menu accessed from the callback line ?
The option does not appear otherwise...
Kind regards
I'll look, thank you. :)
For your information, here are the context menus accessible according to the starting selection:
1°) By the text on the side:
2°) By the sidecut:
3°) By the rappel line:
You can clearly see from which element the access to the menu is made by the appearance or not of functions such as "hide the dimension line" or "hide the reminder line" or nothing between the "Hide" and "Display Options" functions.
Kind regards
