Hello,
I use template tables for the bend values but only for the K factor. The tables were made in accordance with the values of our folding machine.
1 table per thickness/ve/material.
Despite the extreme simplicity of the data in the excel file, it often happens that you have to redo the " sheet metal" function in the feature manager without modifying anything and the error disappears. It's a bit annoying.
Am I the only one to suffer from this hazard?
Windows 11/ Excel MS 365 / SW 2023 SP05
When does it jump?
When it comes to doing the function (so you have to restart it), when you open it?
A screenshot of the error?
In theory MS 365 not recommended, even if in practice never had an error on workstations equipped with this version (on my fixed office license workstation of 2016)
When it's time to unfold.
Well, since it's a priori random and it's not decided, no example to show you
Possibly if it's when unfolding, that's when it loads the table.
We sometimes encounter the problem (loss table at the fold) when we load it (lasts 1-2s).
If already loading on another workstation then it is impossible to create the function. If you restart it, it works (since it's already loaded on the other station.)
One way to test this is to open the excel file on one workstation and try to unfold it on another workstation.
