Hello everyone, how would you go about making this front fork of your bike (see link)? What functions especially because in smoothing it makes me bad I don't get what I want. Thank you all
Hello, what do you mean by "I don't get what I want"? Smoothing seems to be the quickest and easiest way. Personally I will use the boundary boss with the different intermediate profiles and some guide curves...
Unfortunately I am not on my computer until tomorrow morning. The problem with the smoothing is at the "junction" between the two fork tubes and the steerer. It makes me a flat surface, I hope I'm clear enough. Thank you
Thank you for your answers and sorry for the double post...
Why is the boss function more appropriate? (I've always used straightening)
I'm going to find out about the welded mechanic (tutorial or other) because I have very little knowledge in it if at all haha! I'll keep you informed as soon as possible
If you have any other ideas, don't hesitate, thank you in advance:)
Thank you opiep27 for your time. Your smoothing is more than satisfactory to me. Just a quick question, are 3D sketches the guide curves of your smoothing? What about the 2D sketches of your profiles?
I finally get the desired result, I had a sketch pb surely... Thank you again we couldn't have made it clearer in any case by following your method everything is back to normal.
