Hello
I need your talents
I created a cover on solidworks 2016
My problem is this: I can't shape this piece in the direction of height
I know how to shape a classic rectangular piece but not a complex one
I'm attaching a photo if it can help you understand my problem.
Thank you for your answers
If necessary I will attach the solidworks file to you
gedup
3
Hello
Can you send a side view?
If the edges are to remain parallel, this excludes the bending function. I think that classic extrusion-removal of material should be suitable.
gedup
4
Simple extrusion? See attached image
gt22
5
Either your piece is simply a hanger
so it's simple you make a sketch of your hanger so thickness of your piece
you extrude and then you cut on the perpendicular plane everything in volume
where you go through the surface and there you can create bomb backgrounds of complex shape
See this example
http://www.lynkoa.com/forum/modélisation-volumique-3d/dos-bombé-dun-violon-sur-solidworks?page=1
coyote
6
Hello
What function did you use to make your left shape, sweeping, smoothing,...?
Send us your file for more clarity!
Hello
Why not extrude according to the thickness of your plate (side sketch), and then cut it by removing material from above?
Thank you all for your answers
I attach the solidworks file to move my project forward.
A.Leblanc is the closest to what I am looking for.
Part1.SLDPRT
Hello
I inserted a fold in the room now it's up to you to finish inserting your extrusion...
piece1_-_ac_cobra.sldprt
