Hole Wizard 2018 import Excel
Hello;
Has anyone managed to create a new standard for the drilling wizard by importing excel data as proposed by the 2018 version of the toobox?
- I have duplicated an existing standard (ISO)
- I exported the data of these holes
- I modify the excel table (and delete sheet 1).
Well, it doesn't work...
I ran a test trying to import, without modifying it, the data from the ISO standard... it doesn't work either.
Or does the Toolbox request data on keys!?? or the type of data does not suit him (text cell/number format...)
- From what I've noticed: the toolbox can't reimport its own Excel exports from an existing name...
I would like a little help.
Kind regards.
Hi
I've just tested exporting to Excel and then reimporting a single ISO standard hole (Hex Bolt Grade C ISO 4016) and it worked OK.
Was your toolbox a fresh 2018 toolbox or have you upgraded it from 2017?
David
Hi David;
My toolbox is upgraded from 2017.
I already have some personal holes (2014).
Did you delete links to toolbox feature part before reimporting?
There is a way to cancel "Global" links in a new standard?
