Hello, I'm on Windows 7, I installed Draftsight several months ago (it worked fine) but lately it didn't work anymore, I uninstalled it and tried to reinstall it, see in attachment the message that appears during the Install, Google translation: there is a problem with this Windows installation package. A program required for this installation to complete could not be run. Contact your support or package provider. Uninstall -swinstactsvc.exe action, location: command C:\.....\swinstactsvc.exe:-swup DSP/I searched for this file swinstactsvc.exe Unable to find it, the Install was interrupted.
Thank you for your help.
Hello
Have you tried disabling your antivirus before installation?
Hello PhilippeB
Thank you for your interest, no effect I have not disabled the antivirus, I am doing the test and keeping you informed.
Hello
I restarted the installation having disabled the antivirus: always the same message:
There is a problem with this windows Installer package. A program requierd for this install to complete could not be run. Contact your support personnel or package vendor. Action: Uninstall _swinstactsvc.exe, location: C:\ .....\ swinstactsvc.exe, command: -swup DSP .
Moreover, when I search for the famous C:\ .....\ swinstactsvc.exe, I find nothing under the C.
Hello
I had the same problem as you and the following link sent me to a windows-managed install/uninstall resolution that fixed the problem automatically.
I uninstalled draftsight properly and was able to reinstall it behind it.
Here is the link:
https://support.microsoft.com/en-us/help/17588/fix-problems-that-block-programs-from-being-installed-or-removed
