Hello.
Is it possible to insert a sketch and a function in the creation tree?
Example: Add a forgotten extrusion under the Sketch 2 line.
Thank you
Hello.
Thank you
Hello
Yes, it is possible, just drag the blue bar to the desired location:
Do the desired functions and then lower this bar to the bottom.
Kind regards
Yes
If the sketch's baselines are earlier than the position of your sketch 2
In this case you make your sketch at the bottom of your creation tree and once done
you move it to the desired place
Thank you both. Every solution you propose works.
Have a nice day.
