I would like to know if there was a trick/function to prohibit values (intervals) of distances between two components (angular or linear).
Example: a mechanical stroke between two parts that must be between 150mm and 450mm - the goal is to enter a fixed value (and not free like the free slide constraint) but that it warns or prohibits the value entered outside the interval.
I tried to apply Excel functions in " Equation " but without result.
For the angles it's the same but instead of putting a distance value (in red below) you have to put an angle value (in green below). The boundaries are in the 2 cases to be put in the fields circled in blue below.
