Slowness on a part that contains several pieces
Hello,
I have a problem of slowness on a Part. which has several volume parts transformed into sheet metal.
Issue with slow recording of the Part and associated drawings.
Someone would have an explanation please. Thank you
Sincerely,
PTE
A little more rotten information will be helpful in understanding the problem better.
At least a screenshot of the tree structure.
The number of pieces of sheet metal, if part in the context...
If a lot of sheet metal work in a single room + sketching in the context, it's not necessarily crazy the same thing for rehearsals and other functions known to be heavy.
Hello @contactesquisse3d
Can you provide us with the part? And its context?
External links, Insert part into a room, and complex functions in too many, etc...
There are many elements to consider when modeling.
We do multi-body in assembly mode, it's lighter to use
Indeed, @sbadenis, if he has ever transformed his sheets into wire mesh with drilling repetitions, we should not be surprised if it grinds.
A trick that might be to apply: the blocking bar (avoids untimely reconstructions).
Also check that there are no looped constraints (which leads to green lights that never disappear from the tree)
