Hello
It's all in the title or almost.
With SW15, I have a series of general plans to do for a product range. I managed to link the views to the displayed config but no way to forward the config (automatically).
Hello
Hello
No possibility to my knowledge, a macro maybe...
Edit: in fact I may have misunderstood, if we select the view before inserting the nomenclature, then we change the configuration of this view (by right-clicking) and we validate with CTRL+Q, is this the desired behavior?
Ouch!
Selecting the view before creating the BOM does not create a link between the view and the name.
To illustrate
It's a particular behavior (for my taste) that we use, although it is intended by SW
The user opens his model (SLDASM), chooses the config (right or left for example), opens the mep, the views are displayed with the right config. The nomenclature is fixed.
Hello, I agree with the idea of .PL, you can't vary a config with the nomenclature that follows. On the other hand, you can make a different sheet for each configuration. with its nomenclature. But this idea works when there are not 50 configs.
Kind regards.
That's indeed the problem: for the moment we have 8 asm with 8 configs each.
The solution accepted by the customer that allows the problem to be circumvented: a multi-config bill of materials.
